Fuel pump, 1996 eclipse
Old Oct 29, 2003 | 04:42 PM
bfoss88's Avatar
Default Fuel pump, 1996 eclipse
daughter has a 1996 eclipse, that wont start. motor turns strong, but no fire. we didnt hear fuel pump priming, so we suspect that. i pulled the pump out, and the voltage is good to the pump, but the pump doesnt operate at all, not even a shutter. my meter shows when turned to accessory position, at the harness where it hooks directly to the pump, a 12v surge for prime, then a steady 12v when key is held to the run position, but the pump still doesnt operate. tested pump staight to battery and it turns, i cant find any fuses for the pump, or relays either, so i am lost. any ideas? holler at me on AIM on either bfoss88, or melissafoss88 if youd rather talk there. whatever help i can get would be appreciated. thanx.........
MNalfa
17
May 9, 2019 06:07 AM
Germankat
Mar 19, 2008 05:28 PM
Germankat
Mar 19, 2008 06:43 AM
agallardo
Feb 22, 2007 03:46 AM
andyk
Nov 11, 2006 04:54 AM
