FuelFilter - location pissing me off
Old Feb 18, 2006 | 10:48 AM
mysterio2099's Avatar
Default FuelFilter - location pissing me off
Ok, I have been given two locations on this forum.. by the passenger rear tire, and under the battery. I can tell you its not under the battery, I've looked twice. And I dont know how the hell its near the tire, maybe I overlooked. But here's a site I found showing that you have to remove the back seats and ****.
Someone please explain. I'm getting sick of trying to find this thing and it's pissing me off. [:@]
http://www.laser-eclipse.net/workfuelfilter.htm
Old Feb 18, 2006 | 11:07 AM
eclipsed4u's Avatar
Default RE: FuelFilter - location pissing me off
how about this....its attached to the fuel pump...and the fuel pump is in the fuel tank.
Old Feb 18, 2006 | 11:09 AM
that doesn't help me any, it just gives me a 4th location.
Old Feb 18, 2006 | 11:21 AM
eclipsed4u's Avatar
well thats where it is at. the 3G and the 2G fuel pumps are exactly the same. and the fuel filter for the 3G is attached to the fuel pump. so thats where it is at.
you didn't check a haynes manual?
Old Feb 18, 2006 | 11:28 AM
I don't have a manual, so no.
Here's a picture of under the passenger seat... look familiar?? [:-]
I'mnot sure what the area is to the left... I've never did any kind of fuel work .. mez a noob.
Old Feb 18, 2006 | 11:36 AM
eclipsed4u's Avatar
here is a how-to on how to remove the fuel pump from a 3G. i am sure the process is very similar.
http://www.club3g.com/forum/showthread.php?t=23630
Old Feb 18, 2006 | 11:41 AM
the car's are obviously not the same... look at the photo of my car, then look at the photo of the 3G.
Old Feb 18, 2006 | 11:54 AM
Sanguinius's Avatar
Dude easiest way to find the fuel filter is walk the line. Find your fuel line under the car and trace it to the fuel rail. The only way you can replace the fuel filter on the fuel pump itself is to buy a new fuel pump. The sock filter on the pump itself is meant to be changed only with the pump. You won't find them sold seperate.
i removed the left hand side one and that's where all the fuel lines go... whoops.. I also looked down in there and I saw the filter.. I'm guessing I have to jack the car up to get to it.. because there's no way I can from the passenger seats
Old Feb 18, 2006 | 12:50 PM
i found the filter by itself right by the rear passenger tire, i just wasnt looking in the right place last time.. its laying in a little cradle. I just can't seem to get the bolts off... i sprayed them with some penetrating oil.. letting it sit now.. if I can't get it off after that I'm just gonna say screw it.
