gauge lights worked at first but now dont
Old Mar 1, 2006 | 01:25 PM
nukn_futs_demit's Avatar
Default gauge lights worked at first but now dont
ok when i bought the car the gauge lights worked but the car didnt have a radio so i installed one and i thought i had blown a fuise during intsallation but i checked all fuses in engine comaprtment and drivers side floor panel but no fuses were blown well now my radio works but i have to gauge lights so to see my speedometer at night i have a little flourscent light velcroed to the top of the steering column and its looks redneck as hell and i want it gone and all the gauge bulbs have been replaced so is there anyting i can do jus short of buying a new circuit board for the back of the gauges
Old Mar 11, 2006 | 03:07 AM
magnet's Avatar
Default RE: gauge lights worked at first but now dont
I had that EXACT same problem. But what it was for me is that there is a ground wire behind the radio that I forgot to hook back up, and as soon as I seen this and hooked it back up VIOLA! Hope this helps
Old Mar 11, 2006 | 09:24 AM
Threre is a fuse box under the hood too. you should check that out. and check your wireing
Old Mar 12, 2006 | 02:41 PM
ive checked everything i can think of i took my radio back out and hooked up all my wires to the right spots the only thing i didnt hook back up is my cigarette lighter b/c i dont smoke and i even rechecked the back of my instrument cluster so everything is hooked up correctly so if i do have a shot in a wire does anyone know which one exactly goes to the cluster
Old Mar 17, 2006 | 10:34 PM
My93EclipseGS's Avatar
Try rotating your dim swich. I have the same problem every now and then when I would be driving along and lose my lights inside. I would have to move my dimmer switch to get them to turn back on. Sometimes I would have to just push on the switch and they would come on. Anyway if the dimmer switch is not hooked up your lights won't light up either.
Old Mar 18, 2006 | 11:48 AM
ok thnx for the tip but to let you know my high beams and low beams work fine no problem but ill try wat you said thanx
Old Mar 19, 2006 | 03:38 AM
Sanguinius's Avatar
Sounds like it might be a dimmer switch problem or a bad line somewhere. Take your dimmer out and trace the lines that go from it to your instrument cluster. Test with a multimeter for continuity on those. Also do the interior lights work or no? If the interior lights don't work by turning the dimmer all the way to one side then you definately have a bad switch there.
lhausi2
May 8, 2008 09:06 PM
BrunoBoy650
Jun 15, 2007 10:08 AM
pinkglow
Feb 1, 2006 09:22 AM
DragonRacerX666
Apr 20, 2005 12:14 AM
