GOod or bad
Okay.. well after buyin a new iginition coil and discovered the mounting bracket wasn't the same as the one i took out of my car. This made me curious and so i decided to call the person i bought the car off. When i purchased it was told there was a 6 bolt swap. So i thought it was just the bottom end. What i found out was a hole 1st gen 6 bolt engine was put in. So i now have 2nd gen eclipse body with a 1st gen engine. Is this bad ? and would i still be able to use the 2nd gen coils on the 1st gen engine.
ohh the 6 bolt swap install was already done by the previous owner. he bought the car used and it crankwalked and so he decided to just drop in an entire 6 bolt. Now its just giving me random missfire problem when cruising. Have to let rpm drop below 2k then i can accel. But as soon as i cruise for 10-20 seconds it will missfire. Still dont know why, would a blocked EGR and or malfunctioning EVAP system cause it to missfire. Just curious.
thanks for some of the response. my progress so far is i got a new coil and to my bad luck its not the coil. next on my list to check is the CAM sensor since i remember the engine bay was washed and the person who washed it for me likely did not cover it. I have another cam sensor. If that doesnt' fix my problem then my next option is TPS. Wish me luck..
Senyo
06-16-2005 02:19 AM
