GOod or bad
Old Jun 15, 2006 | 08:17 PM
Nubiebubie_GSX's Avatar
Default GOod or bad
Okay.. well after buyin a new iginition coil and discovered the mounting bracket wasn't the same as the one i took out of my car. This made me curious and so i decided to call the person i bought the car off. When i purchased it was told there was a 6 bolt swap. So i thought it was just the bottom end. What i found out was a hole 1st gen 6 bolt engine was put in. So i now have 2nd gen eclipse body with a 1st gen engine. Is this bad ? and would i still be able to use the 2nd gen coils on the 1st gen engine.
Old Jun 15, 2006 | 10:15 PM
5Tizzle's Avatar
Default RE: GOod or bad
edit: didnt read the entire question....dont bother reading this post.
Old Jun 15, 2006 | 10:29 PM
Sanguinius's Avatar
If the coil wire fits on the coil then you can use it. Just have to get the bracket for it to fit. Also a 6 bolt swap IS a good thing.
Old Jun 16, 2006 | 10:02 AM
Nice you got the whole swap. Thats a damn good thing!!!! No crankwalk Also its probably just easier to return the coil and get the right one
Old Jun 16, 2006 | 11:46 AM
slow420a's Avatar
the ports in the 1g head are larger then the 2g, many people do a 1g head swap onto a 2g motor... well 1g 6 bolt anyway. it will work you just need a 2g mounting bracket.
Old Jun 16, 2006 | 07:33 PM
ohh the 6 bolt swap install was already done by the previous owner. he bought the car used and it crankwalked and so he decided to just drop in an entire 6 bolt. Now its just giving me random missfire problem when cruising. Have to let rpm drop below 2k then i can accel. But as soon as i cruise for 10-20 seconds it will missfire. Still dont know why, would a blocked EGR and or malfunctioning EVAP system cause it to missfire. Just curious.
Old Jun 19, 2006 | 09:41 PM
Sanguinius's Avatar
The evap should have nothing to do with a missfire. I'd look at distributor and rotor first see what condition they are in and get the right coil in the car.
Old Jun 20, 2006 | 10:55 PM
thanks for some of the response. my progress so far is i got a new coil and to my bad luck its not the coil. next on my list to check is the CAM sensor since i remember the engine bay was washed and the person who washed it for me likely did not cover it. I have another cam sensor. If that doesnt' fix my problem then my next option is TPS. Wish me luck..
nawgee
Oct 20, 2008 06:24 AM
agallardo
Oct 1, 2006 02:07 AM
Senyo
Jun 16, 2005 02:19 AM
gsxgogetter
May 26, 2005 01:58 PM
red.5gt
Oct 10, 2004 12:35 PM
