got the car started and....
Old Sep 6, 2007 | 07:44 PM
  #21
Default RE: got the car started and....
Eh.. hes pretty car literate.. if he says there is a knock in the motor.. there is a knock in the motor
Old Sep 7, 2007 | 08:50 AM
  #22
moronicicon's Avatar
what have you done? example, if your timing belt had went and you have replaced it, its totally common to have bent valves which cause them not to close fully hense lose of compression on certain cylinders. I have tried a couple of times with customers cars who have had the timing belt strip the teeth or break, to just try a belt and only about 5% have ran good with just that, 95% have had bent valves and the car ran like **** and compression was low. Its just a thought, don't take it as law....... if the wet test doesn't show improvement that is, if it does then its ring issues. Also I just thought if you were tryin lots of times to get it started and it wouldn't start, it could have dumped raw fuel in the cylinders causing the rings to wash out and not seal. Hope that helps with some ideas.
Old Sep 7, 2007 | 11:30 AM
  #23
When you remove the motor, remove the head and inspect that. But the bottom line... is if a rod is knocking... its done.
Old Sep 7, 2007 | 02:52 PM
  #24
Kaede.Noir's Avatar
Yeah also hes not that illiterate like sebba stated before, plus if his timming belt was bad, im pretty sure he'd find out so =) in fact... that reminds me i need to get on that as well.........
Old Sep 7, 2007 | 07:51 PM
  #25
2nd g eclipse gst's Avatar
it sure does sound like a rod and it sure does sound like its coming from the bottom
Old Sep 7, 2007 | 07:56 PM
  #26
guess ill try to get another motor and sell it, also i was backin the car up today to get it out of the way and everytime i hit the brakes the car would jerk and stop,is that the brakes locking up, and theres a loud pop coming from the front driver side....should i just part it out??? i know the tranny is good it shifts perfect in all gears and reverse, and all the interior is there,but one thing i like about it is that it has very cold a/c lol
Old Sep 7, 2007 | 07:57 PM
  #27
and i dont like my post number so ima post this to get past it lol dont get mad guys i just dont like that number lol
Old Sep 7, 2007 | 08:18 PM
  #28
LOL hahahaha.
I dont know what to tell you about the brake thing... maybe parting it would be the best idea
Old Sep 7, 2007 | 11:37 PM
  #29
Kaede.Noir's Avatar
wha wha what?!?! parting that beauty? or the engine to see whats the deal with it???
Old Sep 8, 2007 | 12:08 AM
  #30
nah kaede, if you look at the pics i posted it the off topic section youll see the black eclipse in the background that were talkn about not my gst
