got the o2
Old Feb 20, 2008 | 10:10 PM
itsme71190's Avatar
Default got the o2
i replaced BOTH o2s. rear one was a little of a pain.
anyways
i took the negitive cable off the battery to reset it.
still had a check engine light and smoke was blowng out. which im no worried about cause it should b just left over oil burning..
INPUT?
Old Feb 21, 2008 | 08:31 AM
Default RE: got the o2
how long did you leave it off the neg? What code was your car giving?
Old Feb 21, 2008 | 03:33 PM
itsme71190's Avatar
20secs. n i stepd on brake to drain all power.
36
Old Feb 21, 2008 | 04:25 PM
i would bring it to autozone to get a more accurate engine code than the key dance
Old Feb 21, 2008 | 06:49 PM
chopper1's Avatar
Is the car running smooth or missing???
Have you looked at the plugs or down in the cylinder while the plugs are out. Check the plug wires at the coil. I had a post that was green with corrosion, not much fire there.
Old Feb 21, 2008 | 08:27 PM
itsme71190's Avatar
is backfires a little when i take off. quick little bursts.
i have brand new plugs.
ill get wires.
i still think the cat has something to do with it
GotBoost
Sep 8, 2006 10:00 AM
eclipsegsx
Jul 27, 2005 02:29 PM
ray@ipp
Mar 21, 2005 03:11 AM
03eclipseGT
Oct 18, 2003 02:11 AM
number 8
Jul 19, 2003 12:21 AM
