gs vs gs-t???
Old 12-04-2005, 10:58 PM
slow420a's Avatar
Default RE: gs vs gs-t???
ORIGINAL: eclipsed4u
a GS running 8psi(safe on the 420a) will hit about 250whp.
Neve will happen...210 at the crank.
Old 12-05-2005, 12:42 AM
i really wouldn't worry about the crank walk. If you are than just get a 1st gen GSX and you will be set.
Old 12-05-2005, 10:07 AM
but it has to be a 6bolt not a 7bolt 1G.
Old 12-05-2005, 10:56 AM
eclipsed4u's Avatar
ORIGINAL: slow420a
http://www.hahnracecraft.com/auto/ec...ipsestage2.htm
at 9psi....250-275bhp......so i was a little off, but you are way too low.
Old 12-05-2005, 08:18 PM
dreamz's Avatar
I would go with the first gen but I really like the look of the second gen looks alot better and i dont like the front dash of the 1 gen looks like a cliff fell over
Old 12-06-2005, 07:55 PM
True, I have seen a few GS's with over 300 hp though.. Granted they had more into the motor, and ya I don't believe much of it was stock...
Old 12-06-2005, 08:18 PM
slow420a's Avatar
http://forums.2g nt.com/dcboard.php?az=show_topic&forum=4&topic_id=68886&m ode=full
Hahn lies, kid was running 10 psi on a stage 2 kit, built motor, cams, 52mm throttle body and a bunch of other things and only hit 222whp... your right i was a bit low but for the hp at the crank its not going to hit 250 on a stock motor with only a stage 2 kit at 8-9 psi.
Old 12-07-2005, 10:36 AM
eclipsed4u's Avatar
ORIGINAL: slow420a
boy, the 420a really does suck. but how good was his tune?
Old 12-07-2005, 11:07 AM
go with a gs-t you start with a faster car and if you dont have the money right a way you still have a turboed car to drive around and hae fun that is what i am doing
Old 12-07-2005, 11:39 AM
slow420a's Avatar
ORIGINAL: slow420a
lol good as it can be with what hahn give you. What they fail to mention is that with the 420a(the purpule one on the site) which only has the stage 2 kit and their cat back is that its got a few extras that hahn dosent offer. Hahn has an awsome setup for over 10 psi applications its called the port fuler system(8 injector setup) its an awesome tune but cant control timming and spark so after 15psi or so it takes a bit more to get it going. Back on topic that car has a sfmu which is 10 times better then the cartech fmu that they supply with their kits also they use some sort of stand alone unit or ecu to get those dyno numbers. Ya its a dirty trick but its what they do and most of the time people who boost their cars dont dyno tune if theyare only going to run 8psi.
