GST engine swap
Old 12-09-2004 | 05:34 PM
mike96eclipseRS's Avatar
Default GST engine swap
where can i find a GST eingin swap to replace my stock engine? i need some websites if anyone can help.thanx
Old 12-09-2004 | 05:40 PM
FatalJRA's Avatar
Default RE: GST engine swap
www.japandomesticmotor.com has engines from Japan with low miles on them. They have 4G63 Turbo engines.
Old 12-09-2004 | 10:24 PM
vertstanggt's Avatar
try some local junkyards too, you may be able to find a wrecked one you could get one out of for cheap.
Old 12-10-2004 | 11:56 AM
would i be able to take the 4G63T engine from the 90-94 eclipse and srop it into my car or wouldi have to get it from the 95-99 model year?
Old 12-13-2004 | 08:44 PM
SpyderGS's Avatar
You *can* drop it in....but realize the procedure is long and costly. Either the 1g or 2g engine will fit, but you'll need to change out transmission and axles also.
Old 12-15-2004 | 10:55 AM
get435's Avatar
i thought the gs-t used the same tranny as the gs? at least i was told it did!
Old 12-15-2004 | 04:24 PM
Dans Talon's Avatar
www.rpmrons.com
Old 12-15-2004 | 10:26 PM
SpyderGS's Avatar
It's kind of tricky, the 1g's had almost the same FWD transmission. The 2g's had different engines between the RS/GS and GST's, or basically the non-turbo and turbo cars. The non-turbo cars used a chrysler designed transmission, which BTW is *very* durable, in stock trim it can withstand 450hp. The 4g63's use a Mitsubishi made transmission. Neither transmissions are related in anyway except for the fact that they're both found in DSMs. They don't share any internal or external parts(save for a few hoses i believe). Also, the 4g63 block will not mate up to the 420a transmission. They say you can fab an adapter kit to work, but that's much too expensive, and requires a bit of trial and error. If you are planning on doing the swap though, to my knowledge only 2 people have done it so far. However, they had complete donor cars, since so much needs to be changed. Almost nothing engine related is shared between the turbo and non-turbo 2g cars.
Old 12-19-2004 | 06:07 AM
midnght's Avatar
I am not EVER one to say do not do something. Hell, I am in the middle of a FWD-to-AWD conversion as we type.
This is one exception though. Trying to put a 4G63T engine in a 420a bay is going to require ALOT more than you should pay. It can be done, but at more cost than a new car. The entire engine bay needs to be transplanted basically.
rstoevo
01-20-2013 11:47 AM
kiwii29
07-31-2009 02:18 AM
97gsdragon
02-01-2009 12:43 PM
95HGeclipse
01-23-2006 10:05 PM
magno_313
01-09-2005 12:57 AM
