GSX to VR-4 Trans Swap
Old Feb 6, 2007 | 03:35 AM
confoundedfool's Avatar
Default GSX to VR-4 Trans Swap
So I had my transmission looked at because it was giving me some trouble even after I put in my new clutch. Apparently it needs a rebuild and all that great stuff, probably around 2500 in parts and labor. The thing is I've been wanting a 6 speed for a long time and I know the VR-4 has one. It is also all-wheel drive. So heres my question, does anybody know if it is possible to swap a VR-4 tranny into a GSX? My GSX is a 95 and I know that they make the 6 speeds for the VR-4 from 97 to 99. Any info, concerns, anything would be greatly appriciated. Thanks guys, you have always been a great help before, I just searched for a while and couldn't find anything on this. Let me know.
Old Feb 6, 2007 | 04:13 AM
5Tizzle's Avatar
Default RE: GSX to VR-4 Trans Swap
no not possible without lots of modification, sorry
Old Feb 7, 2007 | 02:40 AM
what kind of modification are we talking? im mainly wondering if it will hook up to teh block
Old Feb 7, 2007 | 04:15 AM
racerx55's Avatar
I thought the GVR4 trans would go right in. you just have to use the transfer case along with it to make the gear ratios work out right cuz it makes it a 5.13 from a 4.92 with the same rear diff ratio.
i suppose it depends on the year...
Old Feb 7, 2007 | 07:18 AM
my only real concern would be that i wouldnt have as good of low end torque in echange for top end... i dont know if it would be worth it, but wouldnt it be fun to have a 6 speed in an eclipse gsx? it would make highway cruising so much easier on gas.
Old Feb 7, 2007 | 07:52 AM
racerx55's Avatar
with a 5.13 youd lose top speed and gain acceleration, plus 6 gears to help that i didnt know they had..... what year of car do you have? Galant VR4 trans swap ive heard goes right in the 1g cars and its stronger trans. What years of what cars are you lookin at?
Old Feb 7, 2007 | 11:13 AM
I know the GVR4 trans and Tcase can be swapped into th 1G.... TheEngineer has the VR4 Tanny and T case for sale it came out of a GSX 1G . But the 6spds I want to say wre on the G VR4 with the v6 2.5l TT so that I doub will work iif that is the case
Old Feb 7, 2007 | 10:49 PM
Nubiebubie_GSX's Avatar
It also works in the 2g also.. I accidentally by chance have a rebuilt one installed. Had to use original front diff and transfercase.
Old Feb 13, 2007 | 03:27 AM
5 speed tranny would hook up the shiftind case in the interior right? but would i have to grab the shift case from the vr-4 6 speed as well as the tranny, transfer case? i just really want it to work, lol
Old Feb 13, 2007 | 09:54 AM
ORIGINAL: Nubiebubie_GSX
what do you mean? you used the original from the vr4 right? because you cant mount just a vr4 tranny onto a 2g without the t-case
