Head bolt studs torque specs... AGAIN!
Old Feb 22, 2007 | 01:19 PM
Default RE: Head bolt studs torque specs... AGAIN!
hes saying he thinks he over tightened. My question is what kinda head studs are you using. Did you buy new factory ones?
Old Feb 22, 2007 | 01:22 PM
agallardo's Avatar
Well, to tell you the truth, i dont think they are stock, and they are not ARP. It was some brand, I THINK. If not then they are the stock ones...
Old Feb 22, 2007 | 01:25 PM
agallardo's Avatar
And yes i already have my Haynes book, just left it at home. Ok, i found the torque specs on dsmtuners. So thats how i got 72. And awhile back we talked about this, and people here were saying 80-100 is fine. My block can handle it (or something like that)
Old Feb 22, 2007 | 01:31 PM
RCJr9186's Avatar
72 is for oem bolts. 80-100 is for arp, they can handle the stress.
Old Feb 22, 2007 | 01:37 PM
agallardo's Avatar
SO, i am good there?
Old Feb 22, 2007 | 01:42 PM
well the reason i was asking if they were stock was to make sure you used the procedure that i outlined. Either way i think your gonna be fine. But the procedure is because the stock bolts are called Torque-To-Yield bolts. You basically stretch them first, then torque them down. Thats why they are pretty much not re-usable
Old Feb 22, 2007 | 01:45 PM
RCJr9186's Avatar
in either case in apx 150-200 miles it's always a good idea to take the valve cover back off and tighten them back down to specs. this will ensure a tight seal for the rest of your engine/head gasket/car's life.
Old Feb 22, 2007 | 01:54 PM
agallardo's Avatar
I did that after 100 miles. well sorda. This is what i did exactly. when i was first doing it, i torqued them at 48 ft.lbs, then loosened them, then 1/4 turn, and another 1/4 turn. (something like that) Well, one hundred miles later, i did some research to make sure, and found 72 lbs on dsmtuners. So i took off the valve cover and torqued them then at 72. And havent done it since. Should i do it again? And keep it at 72?
Old Feb 22, 2007 | 01:56 PM
sounds to me like you did the right procedure. I think you should be fine. And the torque sounds good.
Old Feb 22, 2007 | 01:57 PM
RCJr9186's Avatar
no, if you re-did it, you are good to go. now just look in ur book when u get home and check the specs for the valve cover. (i never do mine to torque specs... i just tighten them w/ a wratchet and it's always worked fine for me.
TheEngineer
Jan 26, 2016 03:32 PM
JASGarcia671
Oct 22, 2014 12:17 AM
cbowman7
Aug 29, 2011 05:28 PM
agallardo
Jan 29, 2007 01:10 AM
RCJr9186
Aug 14, 2006 10:43 AM
