Head pull
Old Jan 30, 2009 | 03:55 PM
97gs's Avatar
Default Head pull
Having trouble getting the head off my '97 GS, have the exhaust, side and front engine mounts, cam gears, valve cover, head bolts out, and timing cover off, would like to keep intake on the head so its easier to swap to new head. what am i missing yet. thanks
Old Jan 30, 2009 | 06:27 PM
Default RE: Head pull
There may be mounts holding the head to the block under the intake manifold. But why did you remove the engine mounts to remove the head?
Is it moving off the block at all? Sometimes there are alot of small hoses that you may be missing or wiring.
Old Jan 31, 2009 | 12:33 PM
TheAdvocate's Avatar
Not sure if the 420a has the same setup as the 4g63, but on the 4g63 it has a bracket on the backside of the head underneath that bolts up to the block, like TE said. I would check that.. And make sure you have all the head bolts out.. Make sure you didnt forget/miss one.
cagedruss
Aug 31, 2006 08:58 PM
paintballproam
Jul 21, 2006 01:46 AM
EMonz57
May 4, 2006 01:14 PM
petro4411
1st Generation
Nov 24, 2005 03:01 PM
rogo_gst
May 18, 2005 08:38 PM
