head work
Old Aug 20, 2007 | 06:39 PM
sloweclipse98's Avatar
Default head work
is it hard to change the cylinder head? mine warpped and i need to replace it. i have the gasket. and new head bolts. is there any other new parts that i need? well besides the head of course.
Old Aug 20, 2007 | 06:45 PM
silvercoupe97's Avatar
Default RE: head work
If you can afford it, I would recommend new valves, lifter, springs, and everything else in between. No sense in getting a new, old, head just to have valve failure later. Also make sure the replacement parts is flat. Take it to a machine shop to have inspected and the necessary work done. Also check the block for possible warping.
Old Aug 20, 2007 | 07:04 PM
antlip's Avatar
Def check the block out. If the block has a related problem from the head then just replacing the head will lead to wasted time and money.
Old Aug 20, 2007 | 08:25 PM
ok well these are the problems im having with it. its a bitch to start. after about maybe 10 trys it turns on an idols fine. then once you touch the gas the slithest bit the temp gauge jsut seems to fly right up and get hot as *****. lol. should i just replace the motor?
Old Aug 20, 2007 | 08:30 PM
As long as everything is still seated... you can jsut get it machined and it shoudl be okay
Old Aug 20, 2007 | 10:02 PM
nick_200321's Avatar
really, if you havent drove it much since your overheating started the block should be fine, but in regards to what silvercoupe said, when you buy a new head or a GOOD used head, it should come with valves and all that. .but if you ran it hot alot, you should check out the block also, but the head should be the only thing bad
Old Aug 22, 2007 | 10:52 PM
yeah cause i never ran it hot at all. once it started going up i shut it off quick. and it still started and idled like a champ so its probably just the head right?
Old Aug 23, 2007 | 12:09 AM
racerx55's Avatar
did you check the water yet? lol
most likely just the gasket is bad.
take your head off and take it to a machine shop and have it checked. dont just assume its warped.
99% of the time the cast block is fine.
Old Aug 23, 2007 | 01:36 PM
willdue's Avatar
check those 2 sensors below the thermo as well...
Old Aug 24, 2007 | 03:55 PM
kmauger07's Avatar
ok so this 100% happened to me but i had a hose problem and just had to hit up the local autozone and got it fixed..my car overheated bad cause i was running late to school but i made it and i was fine afterwards..unless you see obvious problems with your head ide look around for a leak in your hoses or maybe something clogged..good luck though
Red Dragon
Sep 22, 2011 04:29 AM
hoodooman
Sep 2, 2011 07:35 PM
capital 97 tsi
Mar 23, 2009 09:55 PM
mack29730
1st Generation
Aug 13, 2008 11:01 PM
stratman101
Oct 28, 2006 02:23 PM
