Headlight Socket keeps burning up :(
Old Jan 11, 2009 | 10:26 PM
Cydric's Avatar
Default RE: Headlight Socket keeps burning up :(
The only luck I had today was bad luck.
I went to my girlfriend's house to install my new headlights and everything fell apart. I attached my new headlight socket and inserted my new headlight bulb. Did a quick turn of the headlight **** and everything seemed to be in working order. So I fought like heck with my headlight bulb trying to put it back in place correctly using that VERY annoying pin/spring thing that holds the bulb in place. I finally got it in then turned my headlights back on. After a few seconds there was a loud POP. Guess what happened? My brand new headlight bulb BLEW UP!
Now I'm assuming these aren't the right/correct bulbs to be using. So as I go to put my old working bulbs back in, the stupid little pin/spring came off in my hand.
Are these meant to come all the way out? Or did I break something AGAIN? I was so mad that I just said forget and decided I'll deal with the mess tomorrow.
Old Jan 12, 2009 | 04:33 PM
dsm1990gsx's Avatar
You know your not suppose to touch the actual bulb itself, the oils form your hand will make it blow.
Old Jan 12, 2009 | 05:30 PM
Cydric's Avatar
ORIGINAL: dsm1990gsx
Um, yeah. I found that out the hard way.
Old Jan 14, 2009 | 06:27 PM
2slow's Avatar
duh!!!!!!!!!!!!!
Old Jan 14, 2009 | 06:41 PM
Cydric's Avatar
ORIGINAL: 2slow
duh!!!!!!!!!!!!!
Not necessary.
itsmaheshp
Dec 9, 2007 10:31 AM
susie22
Nov 19, 2007 09:16 PM
frank1492
Feb 21, 2007 06:50 PM
jeffery0266
Jan 30, 2006 03:53 PM
Nuggethead 420
1st Generation
Oct 7, 2005 06:12 PM
