help!!!
Old Jul 22, 2007 | 07:28 PM
itsme71190's Avatar
Default help!!!
my ball joint boots are messed up bad. and i found boots for every other car cept the eclipse. and i dont wanna spend over 400 dollars on new control arms.
i need help finding the boots. i need 4.
PLEASE HELP
Old Jul 22, 2007 | 07:38 PM
Default RE: help!!!
Mitsubishi dealership
Old Jul 22, 2007 | 07:41 PM
itsme71190's Avatar
Default RE: help!!!
website? or go to the dealership n ask?
Old Jul 22, 2007 | 08:38 PM
Default RE: help!!!
Dealership
Old Jul 24, 2007 | 09:07 AM
itsme71190's Avatar
Default RE: help!!!
ok they are ganna charge me almost 100 dollars for 6 boots.
am i better off just getin new arms?
Old Jul 24, 2007 | 11:23 PM
davidmitsusrock's Avatar
Default RE: help!!!
100 aint too bad. i say just do it.
Old Jul 25, 2007 | 03:54 AM
silvercoupe97's Avatar
Default RE: help!!!
If the balljoint boots are ripped, the only way to remove any particles of dirt is to press a lot of grease through them as you would with wheel bearings. Another option would just to remove the old balljoints (by pressing them out with a press and that's if you can even replace them..not all are replaceable). You're better off just buying new arms with new joints on them.
What are you getting again? Are you replacing all of the control arms? How about buying a set or two a month? If you can buy two sets, buy the front sets first and then the rear set. The lower, curved control arm is the most important since it can cause you to lose steering capability...it's also under a life long recall (for the life of the vehicle). DO NOT let the dealership tell you any different. The straight piece will come out of your pockets and so will the rears.
Old Jul 25, 2007 | 02:31 PM
itsme71190's Avatar
Default RE: help!!!
ok. well i got them down to 60. so im just ganna get the boots for right now. n ill get arms later.
thanks all for ur help
Black widow
Apr 29, 2014 10:30 AM
pablo1318
Jul 10, 2008 06:16 AM
enzo_hashmat2006
Jul 9, 2005 05:02 PM
