help
Old Jul 23, 2007 | 05:27 PM
Stapes's Avatar
Default help
well i just got a 98 gst and im having trouble with it. did a compression test to see if thats cool and the cylinders were around 135-150 at 7 cranks? is that good or bad? any advice/help is great. im new to mitsubishi so anything is appreciated
Old Jul 23, 2007 | 05:59 PM
Default RE: help
Anything under 143 in the service manual says it needs a rebuild
Old Jul 23, 2007 | 06:06 PM
Stapes's Avatar
Default RE: help
well it was jus rebuilt like it only has bout 600 miles on the motor and we did it at 7 cranks..does that make any difference?
Old Jul 24, 2007 | 04:48 PM
Nubiebubie_GSX's Avatar
Default RE: help
that is low.. for the 2nd gen.and after a rebuild. the difference between each cylinder shouldn't be no more than 14 psi max. I just crank till i get a stable reading.
Old Jul 24, 2007 | 04:52 PM
dorian7's Avatar
Default RE: help
You want to crank it untill it stops moving. Sometimes that is 10 or more cranks. Just till it stabelizes
Black widow
Apr 29, 2014 10:30 AM
pablo1318
Jul 10, 2008 06:16 AM
enzo_hashmat2006
Jul 9, 2005 05:02 PM
