help!!
All i can think of is the axles. If it were the rear with the issue that would be easier to figure out. Im not sure how you would end up with a problem only in the front.
Next time learn to launch first....you need to slip the clutch, you cant just dump it
sounds like you broke the front diff. Its inside the transmission, its actually the 4-spider gear your front axles slide into. The front diff doesn't power to output shaft to the transfer case, so its possible the rear wheels are still getting power, while the front wheels are just dead weight
