help!!
Old Mar 14, 2009 | 09:32 PM
sonicx13's Avatar
Default help!!
i launced my mits gsx the other day and ever since that my rear spins not the front. im guessing its something with the differencial in the front?? help
Old Mar 22, 2009 | 08:55 PM
Xanderthedude's Avatar
You "launced" it? Please explain.
Old Mar 23, 2009 | 09:48 AM
All i can think of is the axles. If it were the rear with the issue that would be easier to figure out. Im not sure how you would end up with a problem only in the front.
Next time learn to launch first....you need to slip the clutch, you cant just dump it
Old Mar 23, 2009 | 04:27 PM
oh_what_up's Avatar
sounds like you broke the front diff. Its inside the transmission, its actually the 4-spider gear your front axles slide into. The front diff doesn't power to output shaft to the transfer case, so its possible the rear wheels are still getting power, while the front wheels are just dead weight
Black widow
Apr 29, 2014 10:30 AM
pablo1318
Jul 10, 2008 06:16 AM
enzo_hashmat2006
Jul 9, 2005 05:02 PM
