HELP!!!! Compression Leak
Old Jul 27, 2010 | 08:41 PM
that would be where i start. If you plan on pulling the motor i might suggest more thing while your at it. Might want to think about the timing belt, tensioner, water pump, ect. General maintenance things that are just simply to replace while you are in there.
Old Jul 29, 2010 | 01:52 AM
Van's Avatar
Van
It's still only 40 psi total. I'd still rec he do a leakdown test. Might save him grief later. At the dealership level we do a lot of leakdown tests to verify which direction a tear down should head first. Warranty pretty much demands it. It's a quick and simple test that might show something else is wrong. Might have a broken ring land and the piece of piston caused a slightly bent valve. We see it all the time. I've had busted piston pieces clear up behind the throttle plate. Guess it just depends on how you are approaching the job.
Christian Jensen IV
Jul 13, 2013 03:13 AM
TheRock0720
Nov 12, 2010 12:30 PM
bossgrabber
Mar 4, 2009 06:21 AM
methanol_manic
1st Generation
Aug 30, 2008 04:32 PM
wega
Sep 30, 2007 11:48 PM
