help coolant leak
Old Feb 15, 2006 | 03:34 PM
novetek's Avatar
Default help coolant leak
i got another question about coolant container they have 2 hoses are they suppose to be connected one is but the other one that goes straight down closer to the haedlight is disconnected? i pretty sure its suppose to be connected to something but i just wanna make sure
Old Feb 15, 2006 | 03:56 PM
novetek's Avatar
Default RE: help coolant leak
I see a lil tube disconnected on the bottom is it suppose to be connected to that damn i wish i had pictures help please
Old Feb 15, 2006 | 06:52 PM
Sanguinius's Avatar
No one of your little tubes isn't supposed to be connected to anything. It's refered to as the overflow hose. The purpose of it is when your radiator gets too hot and builds up too much pressure the cap seal lifts allowing the excess pressure to vent. Well some liquid will go with that. The resevior catches that liquid but also holds a reserve tha the radiator can take from when it is in a vacum. Now when that resevior gets full for some reason (You filled the resevior to the top instead of the line and now the radiator is relieving pressure and putting MORE liquid into the already full resevior), your resevior pushes the excess out the overflow hose and onto the ground. This is to ensure that the majority of the extra gets out under your car instead of blowing up into the hood or spraying on the engine. In other words that hose is fine leave it be.
Old Feb 15, 2006 | 08:00 PM
novetek's Avatar
thanks alot i was really trippin on it because it was leaking alot so that is just the reservoir then how can i tell if my coolant is low? where the radiator cap is should there be alot of coolant i can see there is some but cant tell if its low
Old Feb 15, 2006 | 11:16 PM
NESpeed's Avatar
As long as your over flow tank has coolant in it you should be fine. When the system its self gets low it pulls fluid from the over flow tank.
Old Feb 19, 2006 | 10:58 PM
wicked_outlander's Avatar
check your overflow resevoir, its marked w/ F and L....
Old Feb 20, 2006 | 12:14 PM
ORIGINAL: wicked_outlander
what the hell is this supposed to be telling him
Old Feb 20, 2006 | 04:16 PM
Sanguinius's Avatar
LOL I think he was refering to the 2 lines one being the full and one being the low level line. Keep your coolant between those 2 lines and you're fine. If you've overfilled the system then it WILL spill out as you've been seeing (I'm betting that you've filled the resevior completely?) The essential design is set up to allow enough room in the resevior to fill if the engine gets pressurized and enough for the system to draw the spare if necessary.
ron
May 2, 2012 06:08 AM
ruski
Dec 30, 2010 05:32 PM
Skiddy
Oct 2, 2009 10:41 PM
wega
Sep 30, 2007 11:48 PM
JohnOnt
Oct 28, 2006 05:22 AM
