help my car won't start
Old Nov 21, 2007 | 05:17 PM
x_spyder's Avatar
Default help my car won't start
i have spyder 99 GS single cam here is the problem...
the car running fine until i went tohunt house off country side road. the road have some bump up and downand park my caron the field about 3 hrs later i come back. the caris dead won't start andhave littepower.I do jump start, won't start and i hear choked sound from ther starter.
1. then i check the timing belt was cutting half i think that is the problem.I replace the timing belt and water pump at same time. I replace everything back together my car won't start and still choking.
I don'tknow if i aligned all the markspoint together.
2. I test spark wire no power and i brough new coil ignition and spark plugsstill no power.
I don't know what to do...maybe i mass-up the timing belt....anyone have suggest
Old Nov 21, 2007 | 06:59 PM
dsm1990gsx's Avatar
Default RE: help my car won't start
Do u have an injector pulse? You could have a bad pcm?
Old Nov 21, 2007 | 10:01 PM
nick_200321's Avatar
i would get your alternator checked.. you said it is choking and has little power, your alternator might be shot
Old Nov 22, 2007 | 11:47 AM
tjbiker031's Avatar
did you say that the starter wont turn, just clicks when tryin to turn over?
mysticrythms
Mar 19, 2014 08:17 PM
xhavoc86x
Sep 13, 2013 05:51 AM
lillben07
Jun 28, 2010 07:17 PM
Ithian
Jan 31, 2008 10:21 PM
vivekiny2k
Mar 27, 2007 12:11 AM
