Hiss and No Power at 4500 RPM
I have experienced this problem for a few days now. I have good power all the way up to 4500 RPM and then I hear a hiss (sounds like air) while I lose power. Has anyone else had this problem?
2003 Eclipse GT
No Modifications
2003 Eclipse GT
No Modifications
RE: Hiss and No Power at 4500 RPM
Check your air filter and see if it's clogged or wet. I've had complaints before where the intake would give out a loud whistle during high rpm's and i've found the cause to be a very dirty and wet air filter. With this weather we've been having across the nation- this might be your problem.
Joel, CA
Joel, CA
this is your problem...
check to see if you are missing one or both of these. there should be two plastic rivets holding the stock intake down. most likely, yours are gone. when you hit around 4500rpms, the engine rocks back causing the intake to suck to the bottom of the hood. thats why you are losing power. no air = no power
ORIGINAL: eclipsed4u
ORIGINAL: EMonz57
jerk you beatr me too it.... now doubt in my mind it is this...stock air box not pinned down suctions the hood. did it in my spyder and happens to alot of 3Gs
Thank you, guys. I didn't know this forum existed before I had this problem, but it is a Godsend. The 2 plastic rivets were sheared off and the intake would lift off the metal to which it was meant to be attached. This resulted in no air getting to the cylinder. Indeed, one of the rivets was in the bottom of my air filter box. I was convinced this would be a big expensive problem, but it cost me $1.30 in plastic rivets and took 5 minutes to fix.
Thank you guys so much.
ORIGINAL: agallardo
Does this just happen to a 3G? Because I have a 2G.
ORIGINAL: mclees
