HMC set up correctly?
Old Mar 26, 2010 | 01:41 PM
ProjectDrknss's Avatar
Default HMC set up correctly?
So I finally got myself a Hallman Pro boost controller and set it up. I did a test run and the boost gauge is still showing me a boost of 20 psi +. Running a short route fmic with a evo 3 big 16g and cat back exhaust. I was wondering if I set up the bc correctly. Any input/advices would be really help. On the bc, the output is from wastegate to bc, then input is from the line that runs from the intake to the engine. I spliced it, put a T and had it running to the bc on the input. Thanks.
Old Mar 26, 2010 | 04:20 PM
the input should be from the nipple on the turbo for a reliable boost
Old Mar 26, 2010 | 06:16 PM
Hmm on the turbo, I didn't see anything I i could use for input. The only thing I notice was the one from the wastegate...
azsungal77
Aug 22, 2020 10:04 PM
JustinG
May 25, 2014 08:01 AM
StRyKheR
Mar 1, 2006 06:20 AM
BurntGSX
Jun 28, 2004 10:40 AM
Pinser555
Feb 28, 2004 03:55 PM
