hooking up a boost controller
Old Jan 26, 2007 | 07:22 PM
Simss's Avatar
Default hooking up a boost controller
Ok so i bought a evo3big16 from extremepsi.com and i cant figure out how to hook up my manual boost controller to it, either there is no place to hook up a nipple or im just not seeing it. right now i have stock bcs hooked up to the wastegate.
any info would be helpful
Old Jan 26, 2007 | 07:30 PM
Default RE: hooking up a boost controller
www.vfaq.com
you dont hook it up to the turbo. One end goes on the wastegate the other gets t'ed into a vaccuum line
Old Jan 26, 2007 | 09:56 PM
silvercoupe97's Avatar
Yeah, the charge pipe of the E316G doesn't always have a boost source nipple...it should IMO or I would get one welded on.
Tee it off of the BOV hg tube and you'll be good to go bud.
Old Jan 27, 2007 | 12:24 AM
Simss's Avatar
ok so here's how i have it right now tell me if this is right how i have it
i have a T coming off of the wastegate 1 part going to my bcs and the other going to the manual boost controller
then off the other side of the mbc i have a T going to BOV tube
Old Jan 27, 2007 | 01:36 AM
agallardo's Avatar
I dont think you have to T it off the wastegate line. Just disconnect it off the BCS and hook it straight up to the Wastegate, and other side to the BOV line. Thats it!
Old Jan 27, 2007 | 01:40 AM
ORIGINAL: Simss
It should go like this...wastegate valve---(<--that's the hose, lol)---MBC----T---BOV/Intake (<--you T it inbetween the BOV and intake..you know, that hose that comes from the intake to the BOV).
Here's the vFaq on installing an MBC http://www.belitski.com/cars/talonmo...aqhallman.html
Old Jan 27, 2007 | 03:39 AM
racerx55's Avatar
You dont want the BCS in there if your using a MBC. Leave the wires plugged in, but lose the hoses.
Old Jan 27, 2007 | 05:36 AM
ORIGINAL: racerx55
[sm=exactly.gif]
Old Jan 27, 2007 | 11:05 PM
Simss's Avatar
ah alright, that would probably explain to as why it wasnt working then =P
do i need to plug the lines going to the bcs or just completly take them off?
Old Jan 28, 2007 | 12:13 AM
As long as you don't have hoses connected to the BCS, your good to go, just leave it electrically connected (keep it plugged in)
import1978
Aug 21, 2009 08:13 AM
tarmacES
Sep 29, 2008 11:35 AM
50ul }{4ck3r
Jan 10, 2007 09:37 PM
50ul }{4ck3r
Jan 7, 2007 06:02 PM
EclipseBabe29
May 10, 2006 02:08 AM
