how to check crankwalk
Old Apr 7, 2006 | 02:46 PM
RCJr9186's Avatar
Default RE: how to check crankwalk
awesome thanks guys. thanks for all the help. another question, if you do catch the "crank walking" before it turns into a big problem, how do you fix it?
Old Apr 7, 2006 | 04:04 PM
Sanguinius's Avatar
The only way I know to fix it is a rebuild. Take it easy on the engine if you cantch it you'll need bnew bearings but you won't need to do too much more. Whereas if you keep going with crankwalk you'll likely destroy the engine.
Old Apr 7, 2006 | 05:20 PM
ORIGINAL: Sanguinius
a 6 bolt swap as far as I have heard the 7 bolt motor even if built up still holds the problem because the main problem happens to be oil pressure and it is really bad when the clutch is pressed in to the floor at idle.
Old Apr 8, 2006 | 06:12 PM
i think there was a way to fix some of the problems with hyundai parts as well. Not sure exactly what they were though
Old Apr 19, 2006 | 08:09 PM
badass91hatch's Avatar
hey guys,what is the spec when checking for crankwalk,what is acceptable,and what is not in terms of measuring with a gauge?
Old Apr 19, 2006 | 10:00 PM
There is an actual way to check for it... but you have to have a lift and alot of tools... If you really want i can find it for you.
Old Apr 20, 2006 | 01:14 AM
ok well my car is in the shop right now for a clutch and my guy knows how to check for it i just wanted to know how much play is acceptable so i can tell him that.
Old Apr 20, 2006 | 07:12 PM
DSMTalonAWD51's Avatar
acceptible clearance is .002-.007", max .010"
.030" is when plate starts to rub on the sensor, and .060 is when stalling and ticking starts to occur
c577
Oct 16, 2007 12:03 AM
Tom Piantanida
Apr 21, 2006 11:41 PM
TheEngineer
Jan 26, 2006 09:58 AM
congonator
Dec 21, 2005 11:26 PM
petro4411
Nov 29, 2005 06:06 AM
