how to get my o2 sensor to not fowl with 3"
Old Oct 1, 2006 | 04:57 AM
5Tizzle's Avatar
Default RE: how to get my o2 sensor to not fowl with 3"
heres the cure: http://forums.evolutionm.net/showthread.php?t=114931
Old Oct 1, 2006 | 11:19 AM
agallardo's Avatar
Nice! Thanks.
Old Oct 1, 2006 | 02:44 PM
ORIGINAL: agallardo
why does a 3" downpipe cause the CEL to come on? Thats gay.
reason is because most downpipes eliminate the cat. So theres where it commes from
Old Oct 1, 2006 | 11:35 PM
agallardo's Avatar
But what if you put on a high flow cat? Why would it come on then?
Old Oct 2, 2006 | 06:09 PM
93eclipsegsx's Avatar
beacuse a hi flow cat is less restrictive so the rear o2 sensor will get a higher reading so it will sense that you have a bad cat.
Old Oct 3, 2006 | 12:50 PM
ORIGINAL: 93eclipsegsx
it depends on the type to, because there are some high flows i believe that are designed to still do all the emmisions control and allow it to breathe allittle better, but i doubt those will give you anywhere near the less restrictive ones. I would just go with a straight through system and either an 02 sim or what jeff is trying out
Old Oct 4, 2006 | 10:02 AM
99clipsgst's Avatar
I have a 3" turbo back system and I have never had the CEL go on. The only time it went on for me was when I had a misfire.
Old Oct 4, 2006 | 10:03 AM
ORIGINAL: 99clipsgst
you have no cat and you dont have a CEL, something is wrong there
Old Oct 4, 2006 | 12:41 PM
i never had a cat on my car and it didnt throw a code. maybe its b/c i only have 1 o2 sensor.
Old Oct 4, 2006 | 01:45 PM
yea usually its the second o2 that is after the cat that should throw a code
