IAC Blockoff
No dont do it. You will end up with more idlling problems. Like blocking the FIAV will cause you to have idle problems at cold start where the FIAV is supposed to be working. Your car will want to die out. Removing and blocking these components off is really only good for cars that are built up with a good ammount of mods. It is not a solution to an idle problem
