idle low...
ORIGINAL: agallardo
But to adjust the BISS, it requires a special tool, right?
you very well may have a smakk boost leak somewhere i agree on the idea sebba was thinking
ORIGINAL: Sanguinius
Yes you turn it till it idles where it should (Recommend doing this AFTER the engine is warmed up and set the idle to approximately 750 RPM).
and after adjusting the BISS screw if you still have a prob between shifts and with idle then you have a boost leak , which is likley the BOV if you just installed it and the problem started
