injector install
Old Oct 12, 2006 | 06:25 PM
99clipsgst's Avatar
Default injector install
Can anyone provide me with install directions for putting new fuel injectors into my car. Is it something easy or should I just take it to a shop to pop them in. Also If I do got to the shop how much would a job like that run?
Old Oct 12, 2006 | 06:34 PM
Default RE: injector install
it shouldnt be that hard. You just have to remove the fuel rail first and then the injectors.
Old Oct 12, 2006 | 07:34 PM
Its really simple dude. The hard part will be tuning them.... and that still isnt really hard. It might take you a couple hours to get the hang of the SAFC if thats what ur using.
Old Oct 12, 2006 | 08:37 PM
TheAdvocate's Avatar
I have some settings, just let me know what size injectors and what size turbo your runnin, and I could get you close to the right tuning.. I think its about a total of 6 bolts you need to take off to get the injectors off.. Once you get the fuel rail pulled, the injectors will pull right out, and you can pop your new ones in.. Nothing is holding them in, cept the pressure from the fuel rail once you bolt that back on. You will spill a little gas out of the fuel rail/line when you take it off though. There wont be enough to worry about though. I just took mine off about 3 times when my coil pack went out on my car.. Once you do it, you wouldnt ever take it to a shop to have it done...
Old Oct 12, 2006 | 09:30 PM
Wideband needed to tune otherwise dont tune it yourself thats my input from here
Old Oct 12, 2006 | 11:42 PM
agallardo's Avatar
Yeah, its not that bad. Its actually really easy.
Old Oct 13, 2006 | 09:45 PM
DSMTalonAWD51's Avatar
disconnect fuel pump wire harness and crank car a few times until its dead to get more fuel out of the lines, otherwise you will soak a couple tshirts with all the fuel that comes out
Old Oct 13, 2006 | 09:48 PM
and dont drop the plastic spacers, if you're lucky they fall to the floor, if you're not they land somewhere that you cant reach...
BrunoBoy650
Apr 10, 2007 03:27 PM
dennistan80
Jul 19, 2005 09:42 PM
pc
Jul 12, 2005 10:15 PM
scone
Jul 3, 2005 10:47 AM
wswen842
Nov 16, 2004 04:23 PM
