Injector Question
Old Aug 18, 2006 | 01:09 PM
burnmyeyes's Avatar
Default Injector Question
I don't have a problem, Just a question. In the morning, when I first fire up the eclipse and I start to drive somewhere it doesn't seem to have much power until it warms up a bit. I have 550cc injectors, and I've heard bigger injectors are like that. I just don't know why. How come?
Old Aug 18, 2006 | 02:25 PM
98eclpsrider's Avatar
Default RE: Injector Question
probably because the engine is cold, if you have a GST or GSX then you'll want to baby it until the engine warms up, because if you slam it when the engine is cold it could damage the turbo a little bit.
Old Aug 18, 2006 | 04:56 PM
burnmyeyes's Avatar
Yeah I figured that it wouldnt be good to run the crap out of it first thing in the morning. I never noticed it when I had stock injectors.
Old Aug 18, 2006 | 07:26 PM
slvr_eclipse's Avatar
Im pretty sure its like that with all cars.
Old Aug 18, 2006 | 07:40 PM
yea its like that with most cars. It might just be alittle worse with the bigger injectors but nothing to worry about
Old Aug 18, 2006 | 08:51 PM
ORIGINAL: burnmyeyes
give it 10 minutes to warm before driving... I always do that in my EVO. the EVO has 550s stock. and yes it drives horrible when first started up
Old Aug 18, 2006 | 10:19 PM
DSMTalonAWD51's Avatar
its not just because they are 550s, it is because they are bigger than stock. whenyou put bigger injectors on a car, you increase injector deadtime to compensate for the size. Since they squirt out more fuel, you ahve them open for less time. so they are pretty much shooting in fuel in longer bursts. and also since they are bigger, when the motor is cold the fuel doesnt atomize as well, so the spray patter isnt as fine and the clyinder mixture isnt as good. also, if you are running colder plugs they can further add to the problem. id say jus get used to it. id also say let it warm up for 30 seconds or so, but 10 minutes sounds rediculous, jus take it easy until the motor is warm. I dont know about all cars, but my m3 owners manual specifically states to drive off immediately, and NOT to let the motor idle to warm up.
Old Aug 21, 2006 | 11:32 AM
burnmyeyes's Avatar
thank you. thats exactly what I wanted to know.
Gstfat
Apr 20, 2008 08:04 PM
Gstfat
Mar 25, 2008 06:46 PM
2.0_V6
Feb 24, 2008 05:59 PM
pntballakev
Aug 11, 2007 01:18 AM
burnmyeyes
Jun 27, 2006 11:16 PM
