Interchangeability
Old Jan 28, 2006 | 03:08 AM
Rev2Red's Avatar
Default Interchangeability
I currently have swaped the eclipse engine in my Mirage i am changing the pistons to the 9.5:1 compression new ones and i am ussing a fuel pump from a 3000GT which is already in the works, I was wondering how much better the EVO turbo is and is the power band identical to the eclipse, Also how well dose it fit together
Thanks
Old Jan 28, 2006 | 09:59 AM
Default RE: Interchangeability
the eclipse turbo stock depending if its a 2G turbo is bad if it is 2G then you have the T25 which is worthless the EVO uses a 16G which flows better and more effeceintly so it can make more power and has a higher tolerence for more boost PSI. the 14b is the stock 1G turbo which is pretty good but the 16G is still a little better than it.
Old Jan 28, 2006 | 10:01 AM
ORIGINAL: EMonz57
oh and the EVO turbo you would prob. need yould be an EVO III .....the newer EVOs use the Twin Scroll big 16G I dont think it will fit.
96me
Apr 2, 2009 11:39 PM
93eclipseN/A
1st Generation
Jun 29, 2008 09:59 PM
zman
Nov 10, 2003 11:34 PM
zman
Nov 10, 2003 11:31 PM
