just hit 60k
Old Feb 4, 2008 | 03:53 PM
johnyredd99's Avatar
Default just hit 60k
I just hit 60000miles and I know that the timing belt needs to be done but i am wondering what else I should have looked at and done while the car is in the shop?? going to get the tires balanced and allignment but not sure what else i should have the shop do. any suggestions would be great
Old Feb 4, 2008 | 04:20 PM
Default RE: just hit 60k
well if they do the timing belt you should do the tensioner as well. Other than that anything else should have already been done like the normal maintenance and tune up stuff
Old Feb 4, 2008 | 04:22 PM
RCJr9186's Avatar
agreed, just a regular tune up should do you just fine.
i was just looking at the mods that you have in ur Sig. i'm just curious if you plan on running a bigger turbo in the future. having a Greddy Big FMIC with the stock t28 is acutally hurting your car more than it's helping b/c of the pressure drop w/ such a small turbo pushing such a small amount of air.
Old Feb 4, 2008 | 04:25 PM
RCJ a t28 is not a stock turboPay attention
Old Feb 4, 2008 | 04:27 PM
RCJr9186's Avatar
wow, did i just say that?
Old Feb 4, 2008 | 04:33 PM
haha, yea i figured you probably just confused it
Old Feb 4, 2008 | 04:35 PM
RCJr9186's Avatar
well while the timing belt is off, it's not mandatory but you could just call it preventative maintenance to go ahead and change out the water pump. i think they are good for 100-120k miles but if the belt was off i'd go ahead and have it done, i think it's like another 50 bucks for a shop to do it as long as everything is off and out of the way.
Old Feb 4, 2008 | 06:55 PM
thanks guys.. yea was looking for the things that i should do as long as the engine is already torn apart. and yes the turbo is not stock its just a little bit larger. doesnt do much help thru first and second... (thats ok cause AWD takes care of it) but 3rd thru 5th look out.... just enough mods to still pop the hood and be a sleeper.... everyone doubts it cause they look and see the 'stock' turbo untill they take a run and then they wonder how this "old" eclipse just ran them
Old Feb 4, 2008 | 09:36 PM
Change your fluids : )
You need: Timing belt, tensioner, water pump...
Tranny, differential etc....
Old Feb 4, 2008 | 09:41 PM
estraw's Avatar
you should do your other belts to like your balance shaft belt and whatnot, if that breaks, it can tangle with your timing belt and break it. hence destroying your engine
*~Daaaamn~*
Jul 5, 2006 09:33 PM
reacted
Jun 10, 2006 04:50 PM
melt012
Jun 8, 2005 04:34 AM
Trader4Less
Apr 18, 2005 06:08 PM
ray@ipp
Aug 21, 2004 05:54 AM
