knowlegable only plz
Old Jan 13, 2009 | 10:39 PM
2slow's Avatar
Default knowlegable only plz
okay just got done putting my reworked head back on and now i turned my turbo into a ticking time bomb i blew the shaft bearing and basically i can move it up and down ? is rebuilding this turbo worth it or did i totally blow it orr is it cheaper to buy a aftermarket replacement ?
Old Jan 14, 2009 | 08:53 AM
Default RE: knowlegable only plz
Do you still have a stock turbo? Its probably gonna be easier to just replace it with either a used t25, or 14b (with a j-pipe). Or try to find one that is already rebuilt. Some companies might offer a core charge on rebuilt ones.
Try giving Hahn a call
http://www.turbosystem.com/hahn/part...ir%20parts.htm
they offer the service so they may offer rebuilt ones with a core charge
Old Jan 14, 2009 | 03:28 PM
dsm1990gsx's Avatar
What turbo is in your car now?
Old Jan 14, 2009 | 05:49 PM
If its a stock turbo, just upgrade it to a 16g.
Old Jan 14, 2009 | 06:06 PM
2slow's Avatar
yeah its stock. so whats the difference between the stock and a g 16 obviously its bigger and forces more air but do i have to upgrade my fuel system or have a reflash on my ecu
Old Jan 14, 2009 | 06:24 PM
Nope, your fuel system is more than capable of compensating for the higher volume of air at stock boost.
Old Jan 14, 2009 | 06:39 PM
2slow's Avatar
sweet
Old Jan 14, 2009 | 06:40 PM
dsm1990gsx's Avatar
You'll need an 2g install kit for the 16g turbo.
Old Jan 14, 2009 | 06:44 PM
That typically comes with it.
Old Jan 14, 2009 | 06:47 PM
dsm1990gsx's Avatar
ORIGINAL: Sebba
Not if you get one used. Just thowing it out there.
