Looking to buy...
Old Oct 19, 2008 | 10:28 PM
97gsdragon's Avatar
Default Looking to buy...
So I'm getting ready to buy a GSX. Its got about 90xxx miles on it. The guy tells me that there is a fuel problem and it's only running on 3 cylinders, but there are sparks on all 4. Does this sound like a money pit? What could be the cause of this? I just don't want to buy it, then have to spend more money than i paid for to fix it, you know?
Old Oct 20, 2008 | 07:03 AM
Default RE: Looking to buy...
Well first off how much does he want for the car, because that will determine wether its worth it or not. Now the three cylinder thing sounds retarded to me. If you have a mechanic that you trust i would ask the guy if you could have it checked over. Also it might be a good idea to do a comppression test on it. It is very easy to do and a tester is pretty cheap. That will tell you alot about the motor.
Old Oct 20, 2008 | 07:20 AM
97gsdragon's Avatar
He wants $2500 for the car. If I do end up getting it I will be dropping a 6 blot in there, so I only need it to run fairly good until spring comes. And what is a good compression for the eclipse by the way?
Old Oct 20, 2008 | 10:25 AM
Compression should be 178psi with a service limit of 133psi. But dont be alarmed if they are in the 150psi range. I wouldnt doubt it on an older car, as long as they are all close across the board
Jerigorn
Dec 21, 2012 08:37 PM
NeoGeo2k2
Jan 21, 2007 10:15 PM
DasPhunk
Nov 28, 2006 07:24 AM
Jerigorn
Sep 1, 2006 01:55 PM
kodam
1st Generation
Oct 12, 2005 10:08 PM
