low oil
Old Mar 13, 2006 | 12:32 PM
novetek's Avatar
Default low oil
My oil light came on how many quarts should i put in?
Old Mar 13, 2006 | 12:39 PM
93eclipsegsx's Avatar
Default RE: low oil
your car should take 4.5 quatrs if you were doing an oil change. so start off with one and wait a little bit and check the dipstick and see where it is.
Old Mar 13, 2006 | 12:49 PM
Default RE: low oil
Just check the dip stick first and see how low it is, then add some, check again, ect.
Old Mar 13, 2006 | 12:58 PM
slow420a's Avatar
Default RE: low oil
Depends on what car you have, if you have a 420a the oil light will come on if you make a hard left hand turn... which is "normal" for that to happen. The problem lies with the oip pan shape and the amount of oil its suppose to have. 4.5 quarts is too much and creats drag on the crank, 4.00 is too little, during hard left hand turns the crank starves for oil. 4.25 seems to be the best level, but thats only if you have a 420a.
Old Mar 13, 2006 | 01:26 PM
Sanguinius's Avatar
Default RE: low oil
Gotta LOVE the way they design these things eh?
Old Mar 13, 2006 | 01:41 PM
eclipsed4u's Avatar
Default RE: low oil
drain it all, then fill'er up. i have never been a fan of adding oil in between oil changes
Old Mar 13, 2006 | 02:00 PM
Default RE: low oil
ORIGINAL: eclipsed4u
to me as long as its under a quart adding some is ok. It really won't effect anything. I guess it also depends on how long its been since the last change. after 1500-2000 you might as well do it.
Old Mar 13, 2006 | 02:08 PM
novetek's Avatar
Default RE: low oil
YEAH ILL PROBABLY CHANGE MY OIL ITS N NEED OF A TUNE UP I WAS JUST WONDERIN IF I SHOULD JUST ADD A LIL THANKS ALOT
Old Mar 13, 2006 | 05:34 PM
Default RE: low oil
Im glad someone said it lol
How long between changes have you been, 3000 miles your light shouldnt come on. and if it does that is not a good sign. I do my oil fully synthetic Moble 1 oil and filter every 1500-2000 Miles...better safe than sorry
I mean I am driving to Mass I am changing my oil before I go and after I get there it is a 1500 mile drive
Old Mar 13, 2006 | 06:42 PM
eclipsed4u's Avatar
Default RE: low oil
ORIGINAL: TheEngineer
if your oil is low and you are under 1500 miles since your last oil change....then you need to get that oil leak checked
