Lowering a 98 gs..
Old Apr 19, 2009 | 07:20 PM
zero_Wheeler's Avatar
Default Lowering a 98 gs..
how much can i lower it without rubbing? , ive got 18's with low profile Toyos.
Thanks,
Old Apr 19, 2009 | 07:54 PM
you dont want to lower much more than 1.5-2" because you will get bad negative camber. I wouldnt even bother going more than 1.5"
Old Apr 21, 2009 | 11:35 PM
Nubiebubie_GSX's Avatar
I have brand new tokico struts and shocks and those lowered my 2nd gen gsx to 1.8 approx. I have 235/40/18 and 3 of my wheel dont rub. The front driver side does but not crazy. It hit the top plastic shield in the wheel well. The driver side seem to be slightly lower enough that i can't fit 2 finger in between the fender and the tire. But on the opposite side I can. It also threw my camber off quiet significantly. approx -2.8 degrees all around. So camber kit a must. Hope that little bit helps in your decision. Some speed bumps i can't take so listen to the engineer on his dont go lower than 1.5 inch drop.
Old Apr 25, 2009 | 06:11 PM
okay yeah thanks that did help..
if i drop it 1.5, will i need a camber kit? and ill a local tire barn or such do an allignment?
Old Apr 27, 2009 | 06:28 AM
if you only go with basic lowering springs that do 1.5" you should be fine on camber and alignment.
Old Apr 28, 2009 | 03:40 PM
okay thanks =D
ray@ipp
Mar 21, 2005 03:11 AM
96gsxpimpin
Jan 9, 2005 12:33 AM
m3kgt_99
Nov 24, 2004 08:31 PM
unplugged_nate
Jun 30, 2004 02:43 PM
Eric Cannon
Apr 9, 2004 02:31 AM
