MBC Problems
Old Aug 1, 2007 | 01:49 PM
Pribs's Avatar
Default MBC Problems
My MBC is not working or something is restricting it for some reason. I have all the supporting mods for it to run 15psi like its nothing but it won't go up at all. I installed it right because the first day I had it I adjusted itto get my boost to peak at 15 psi then I drive my car the next day and it won't peak a hair over 12psi. Between days i removed my bumper cover in preperation to install my FMIC but long story short it never came in the mail. So I put it back onand didnt change anything. I am running a 255 pump and 550 injectors with the stockside mountintercooler. other mods are in my sig. Any1 know what the problem could be?
Old Aug 1, 2007 | 01:50 PM
atown420's Avatar
Default RE: MBC Problems
did you tee your mbc into the line or no?
Old Aug 1, 2007 | 01:58 PM
Pribs's Avatar
No I have one end running to the turbo and the other to the waste gate. Should i instead of running the line to the tubo should i run it to the line coming off of the BOV?
Old Aug 1, 2007 | 02:04 PM
atown420's Avatar
well i have mine on my gst setup like you do i dont know what would really cause maybe a bad mbc i dont know man.I really hope some of the pros come give us their advice. they seem to bemuch more help than i am
Old Aug 1, 2007 | 08:55 PM
Pribs's Avatar
any ideas?
Old Aug 2, 2007 | 12:59 PM
Pribs's Avatar
just upin the thread. I really could use some help please. My warranty is about to go up on my MBC andneed to know if it was me doing something wrong or its broke.
Old Aug 2, 2007 | 04:15 PM
silvercoupe97's Avatar
Do a boost leak check Pribs.
Old Aug 2, 2007 | 07:56 PM
tjbiker031's Avatar
x2
Old Aug 3, 2007 | 01:45 AM
Pribs's Avatar
I'll def do a test tommorow but its strange I had my mbc set at 15 psi then it just seems likethe mbc isnot even there. I turn it all the way down or all the way up and stil at 12 psi. I couldsee it not going up because of a leak but wouldn't itatleast go down when I turnthe boost down?
Old Aug 3, 2007 | 01:49 AM
Yeah, it should. What kind of MBC is this again?
What kind of bov do you have again?
