MBC question
Old Apr 15, 2006 | 01:45 AM
DixonsGst's Avatar
Default MBC question
ok i know when you install a mbc you splice it in between the hose coming off the compressor housing and the wastegate. My question is what do you do with the BCS hose that connects at a 3 way T with the compressor houseing and wastegate?Do you just cap off the BSC and forget about it or what? BTW im driving a 97 gst. Oh and another thing i just bought a boost gauge and its mechanical and i not quite sure how to install the damn thing...it came with a long plastic tube and some wires and a couple of brass fittings.
Old Apr 15, 2006 | 04:13 AM
93eclipsegsx's Avatar
Default RE: MBC question
the wires are so that you will be able to see it at night. the plastic tube is so that you have something to out of the back of the gauge where you'll have to connect to a vacume line off the turbo.
Old Apr 15, 2006 | 04:34 AM
DSMTalonAWD51's Avatar
think of the bcs as a 'stock' boost controller, except its non adjustable. so yes you just cap it off or remove it from under the hood completely and install the mbc in its place
Old Apr 15, 2006 | 03:17 PM
DixonsGst's Avatar
alright ill take off the BCS thanks. As for the boost guage im hooking it up today and dont know where to tap it into. Do i run it to the vacume source thats going to the stock boost guage? Im kinda lost on the guage part any help or instructions would be a big help!
Old Apr 15, 2006 | 03:38 PM
just use a T and tap into the return side of the boost controller.
Old Apr 15, 2006 | 05:25 PM
t the boost gauge from a vacuum line going to the intake manifold on the driver side next to the brake fluid resevoir
Old Apr 17, 2006 | 12:08 AM
DixonsGst's Avatar
alright well i tapped a T into the line going into the manifold right next to the brake fluid resevoir and its peaking at 17psi in third gear!!!!!! I dont know whats going on but there is no way my stock (t-25) is puttin that out. I have an intake and turboback exhaust no cat with intercooler piping and bcs removed but still that shouldnt be that high. Even if it is accurate i should be hitting fuel cut so i dont know whats up. I might take the gauge back and try another one. Any idea why its reading so high?
smarsenal
Feb 19, 2008 08:50 PM
lhausi2
Feb 1, 2008 09:39 AM
99clipsgst
15
Aug 25, 2005 04:41 PM
USCordia
Aug 13, 2005 06:41 PM
drewblueeye
Jul 9, 2005 03:42 AM
