MBC Setup
Old Jul 8, 2006 | 01:22 AM
  #21
agallardo's Avatar
Default RE: MBC Setup
I think I can screw something in there. But if I can unscrew it, would that be it?
Old Jul 8, 2006 | 01:33 AM
  #22
93eclipsegsx's Avatar
it should be.
Old Jul 8, 2006 | 01:39 AM
  #23
agallardo's Avatar
So if I could screw something in, I should screw something in there to plug a hose to the MBC and then to the wastegate, right?
Old Jul 8, 2006 | 10:21 AM
  #24
Keep in mind that the 16g will max the fuel system out earlyer than a 14b would. Just upgrade your injectors and fuel pump you will be fine!
Old Jul 8, 2006 | 02:47 PM
  #25
ORIGINAL: agallardo
yes.
Old Jul 8, 2006 | 07:41 PM
  #26
agallardo's Avatar
Thats what I am planning on doing, but when I get all those things I want to turn up the boost also of course with a wideband and SAFC. But, I am pretty sure my MBC is not setup right though. So I want to set it up right.
Any of guys have a MBC setup, that can take a picture to see how you guys did it? That would me out alot.
Old Jul 9, 2006 | 03:10 AM
  #27
agallardo's Avatar
Yes I can screw something in there. But I cant unscrew anything. Does this help?
Old Jul 9, 2006 | 02:22 PM
  #28
then it must be a hole to hold something in there. im kinda wondering kinda the same thing but is it possible to drill a hole in your compressor housing and put a fitting in there.
Old Jul 9, 2006 | 07:40 PM
  #29
agallardo's Avatar
Hey man, thats what I was thinking too. I met a guy yesterday with a turbo eclipe but with a small 16G and he has a tip with a hole at the end on the j-pipe. So he has his MBC connected to that and then to the wastegate.
But I was thinking, what if I disconnect my MBC? and not have one? will I have stock boost again?
Old Jul 9, 2006 | 08:09 PM
  #30
i dont know but i would try what the kid did and see if that works because that way will work.
