motor mounts
Old Oct 17, 2008 | 06:21 AM
Default RE: motor mounts
i think he may have thought you owned a turbo. Youll have to look around for the 420a mounts since that is the only ones that will work
Old Oct 17, 2008 | 07:58 AM
silvercoupe97's Avatar
I did, my bad. I've seen 420a inserts too. Look in JEGS and JCWhitney. Remember that the 420a is a Chrysler motor. If I find a set from of Prothanes, I'll post the site for you, unless you or someone else gets to it first, Shadow.
Old Oct 17, 2008 | 12:42 PM
shadowmancer's Avatar
arite cool thanks, im on the search right now.
how bout these? doesnt really give a lot of info though
http://www.jcwhitney.com/autoparts/P...t=motor+mounts
this 1 is all 4
http://www.ajusa.com/details/index/1...WD%20NON-TURBO
Old Oct 17, 2008 | 02:01 PM
i told you also check out www.cimotorsports.com or www.hahnracecraft.com
Old Oct 17, 2008 | 03:47 PM
so it looks like these would do the job? says its a set. not bad price.
http://www.cimotorsports.net/motor-s...alon-420a.html
sorry if this is getting annoying i just need some insight
Old Oct 17, 2008 | 07:03 PM
ORIGINAL: shadowmancer
Yup, that's them alright. I see both side inserts and the front and rear inserts. It looks like the front and rears are going to be easy. The sides, you have to remove the rubbers and the sleeve that they are attached to with an press or DIY style (just got to be creative with that, lol).
Old Oct 18, 2008 | 12:59 AM
thats for your help TE and silver, appreciated. i bought the set, and think ill just take it to a shop to do. i probably dont have the right tools for the job.
Old Oct 18, 2008 | 03:58 AM
OMG, I did the driver's side today and it was a PITA to remove!! I cut the rubber out with one of my electric saws (easy part), then cut the sleeve into four sections and it was still hard as doo doo to remove. It took me 3 hours just to hammer that thing out. Those sleeves are on there good. Once I got it out I cleaned it out and smoothed it out with a wire brush and pressed the inserts in with my vise and voila. That one mount took a total of four hours. I also had a spare driver's side mount to work with, so I wasn't in any rush. I did try to go as fast as I could though. It would have taken less time if I had an arbor press. lol
The passenger's side will go to a shop because I'm not going through that again.[:@]
Old Oct 19, 2008 | 01:54 PM
the shop im gona go to does labor for 85 or 95 bucks an hour. think id rather pay that than do it myself and use all that time up and frustration.
Ralliart3000
May 21, 2008 07:13 PM
enzo_hashmat2006
Jul 20, 2005 02:40 AM
jeepstud
Jan 20, 2005 03:20 PM
jeepstud
Jan 19, 2005 08:12 PM
1398spdr
Sep 5, 2004 09:11 PM
