mounting an intercooler
Old Aug 15, 2006 | 05:42 PM
X Treme's Avatar
Default mounting an intercooler
I was just curious as to how hard it is to mount an intercooler under the front bumper because I would like to do it myself. I have a 95 GS-T that I'm going to swap a 97 front onto. I also don't have the intercooler, I'm just asking the question. I do plan to get a Hahn Intercooler being as it is the cheapest that I've come across.
As a side note, I have seen a GReddy intercooler that was an 18v and a 24v, I believe, so what do the numbers mean?
Thanks.
Old Aug 15, 2006 | 06:56 PM
agallardo's Avatar
Default RE: mounting an intercooler
Front mount, right? Do you have the stock turbo?
DON'T put on a front mount without upgrading the turbo. If you have stock turbo, you will lose power with a front mount. And before you upgrade your turbo make sure you put in the supporting mods. Then put on your front mount.
Old Aug 15, 2006 | 11:08 PM
BrunoBoy650's Avatar
ORIGINAL: agallardo
you can have a FMIC with a stock turbo, as long as your going to max it out with the fuel pump, SAFC ect...
Old Aug 15, 2006 | 11:31 PM
i still wouldnt advise putting a front mount with the T25 because it of the way it was made, even maxing it out it wont flow totally efficient with a FMIC.
Old Aug 17, 2006 | 01:34 AM
X Treme's Avatar
Thanks a lot. I was going to put on an intercooler before the turbo because i thought it would be helpful. My plans are to add a EVO III 16g turbo and FMIC, downpipe, turbo manifold, boost controler and boost gauge (Next step), a crushed 1g BOV*, and a custom turbo inlet pipe (http://www.dsmtuners.com/forums/showthread.php?t=57364).
Right now the mods I have are a GReddy EVO2 3" cat-back exhaust, cut my BOV dump tube (sounds much better) and added an aircone, took out my BCS restrictor and the stupid silencer.
*I was searching the web for the FAQ for the inlet pipe and found a FAQ addressing the 1g BOV. It talks of replacing the stock 2g BOV w/ an EVO VIII that is very similar and is tested at 15lbs and 23lbs.
Old Aug 17, 2006 | 01:35 AM
X Treme's Avatar
**** is dsmtuners, and i hope i didn't break a rule.
Old Aug 17, 2006 | 01:38 AM
X Treme's Avatar
DAMN[:@]
chadinfla
Oct 12, 2006 06:05 AM
devono
Mar 1, 2006 03:15 PM
92_laser
1st Generation
Jan 5, 2006 06:02 PM
ImAzn2
Jan 23, 2005 11:41 PM
TheAntiCivic
Aug 13, 2004 02:37 AM
