my covertable top wont go up or down
Old Feb 28, 2011 | 01:51 PM
98Eclipse2G's Avatar
Default my covertable top wont go up or down
i know its not the switch in the trunk. when i try to retract the top the motor just wines. it must be a belt in the motor or a gear stripted, however it works. please help thanks
Old Mar 2, 2011 | 10:39 AM
shaggy76078's Avatar
Is the top currently up or down? If it is down, have a buddy look down from the side towards the gears and see if the gear is actually spinning. If it is up, you will have to remove the entire back seat to even have a chance to see the gears. ....Hopefully it is stuck up though, being stuck down would be horrible.
Old Mar 3, 2011 | 02:27 PM
i can move the top up and down freely. iv seen the gears and they are not move but like i said, i can still hear wines
Old Mar 3, 2011 | 02:34 PM
first, I would double check the switch in the trunk to make sure it is not shorted out. Make sure when you flip it one way it whines and another way it doesn't. Then, I would check the fuses for the top. It is possible you haven't stripped a gear, but had pulled it off the gear system. Generally, if it came off the gear system it just needs to be realigned and it should start working again. Worst case scenario, take it to a dealer and ask them to look at it but not fix it yet. They might hear it or look at it briefly and know exactly what it is.
Old Mar 3, 2011 | 02:39 PM
iv done the test for the switch. ill check the fuse soon. any gear that i do see is not moving.. is there a gear thats hidden?
Old Mar 7, 2011 | 06:18 AM
not that I know of, but you never know....I have not had to replace a convertible top so I'm not the best to ask about this.
SheaBaby09
Sep 13, 2013 06:17 AM
98Eclipse2G
Mar 3, 2011 02:35 PM
Spydah
4th Generation
Sep 25, 2010 11:22 PM
davebern
Aug 23, 2007 11:02 AM
Topdjdotcom
Mar 15, 2007 01:16 AM
