My new toys :)
Old Aug 2, 2007 | 04:48 PM
Natedogg89's Avatar
Default My new toys :)
Got my new parts installed today! Turbo XS BOV and MBC running 15lbs. Now before anyone says anything, yes i know i am venting and i'm not suppose to but i need to get my fix of that nice pshhhhh for a little while. Then i will recirculate it. Thats the only good place i could find to mount the mbc, where do you guys mount them?
Old Aug 2, 2007 | 06:05 PM
Nubiebubie_GSX's Avatar
Default RE: My new toys :)
My friend has that in his gst spyder and it vents out, causes his car to studder and stall when coming to a stop. He had to add spacers to help with it. Hope u dont get that issue.
Old Aug 2, 2007 | 07:14 PM
50ul }{4ck3r's Avatar
ORIGINAL: Nubiebubie_GSX
it never did on my spyder....gotta have it tuned to use it vented
Old Aug 2, 2007 | 07:23 PM
Dusty Eclipse's Avatar
For some reason I always thought u VTAd Nate...
Uhm, other Nate... (Natedogg), I really hope u plugged that post filter hole that was left after you took the recirc hose off... I mean, it LOOKS like u did. Im just making sure
Old Aug 2, 2007 | 07:41 PM
silvercoupe97's Avatar
My MBC is on the far left bolt. Let me see if I can find a pic...nice valve cover btw.
You can kind of see my black Hallman on the left corner of the radiator.
[IMG]local://upfiles/10268/B9C40C432E054BEA9DB1A6A199CD7623.jpg[/IMG]
Old Aug 2, 2007 | 07:45 PM
tjbiker031's Avatar
i heard that if you make a recir tube out of metal, because of the acustics in it, its suppose to make a nice loud pshhh sound...thats what i heard anyway.
Old Aug 2, 2007 | 08:01 PM
Somewhat true, acousticly anyway. A thin aluminum(?) tube would likely create a sound more pleasing to the ear than the stock ABS plastic one.
Old Aug 2, 2007 | 08:06 PM
I did that. My old 1G bov and it was louder than with the rubber tube.
[IMG]local://upfiles/10268/710D637DD91F4A62AD55160106D191D7.jpg[/IMG]
Old Aug 2, 2007 | 08:44 PM
Natedogg89's Avatar
Dusty - Yes i did plug the hole on the other end of the recirculation tube.
Silver - Thanks and ill have to try mounting it over there and see if i can get it to work. When i tried it today the coolant bottle was giving me problems
I really don't have any problems with stumbling or it wanting to die. It idles just like normal and nothing different with the shifts like stumbling or anything. I mean i know its running rich it just doesn't show it. Just like the old stocker recirculated minus the boost leak.....
