Need Advice with Speed
Old Sep 29, 2003 | 05:00 PM
JonnyBlade21's Avatar
Default Need Advice with Speed
I have a 99 eclipse rs automatic. </P>
Im lookin to spend about $200 as of right now to pep up the eclipse a little bit but i know very little about cars. can anyone help me or give me any advise on what to look for. I just dont have enough acceleration. that is what i am really after. i thought maybe an intake but someone said it wouldnt even help much because i have an automatic. someone else told me to go with a throttle body kit and a fuel pump. any help would be appreciated.</P>
thanks alot</P>
</P>
Jonny</P><edited><editID>JonnyBlade21</editID><editDate>37894.6154166667</editDate></edited>
Old Oct 1, 2003 | 05:36 PM
Eclipse95's Avatar
hi there</P>
as far as i know.. i heard the first thing to do to get some horse power is to add an intake... then change to a performance muffler.. i heard from my mechanic that it will be really good if u could change the full exhaust system... if u want to change the full exhaust system u will be spending around 300-400 dollars in ebay for a hks or cat back exhaust system...</P>
Old Oct 3, 2003 | 12:37 AM
sleeper??'s Avatar
unless your wanting 10-20hp keep saving</P>
but if taht what you want either a cheap exhaust or a decent header</P>
Old Dec 6, 2003 | 04:10 PM
EJ20GBD's Avatar
id like to see a 10 - 20 hp gain from a RS eclipse with header intake and exhaust <IMG src=smileys/smiley5.gif border="0">I dont mean to bag but you guys have to realise on a naturally aspirated motor opening up flow isnt gona give you astronomical amounts of power, you'll see 8 - 9 HP TOPS and your torque will probaly gain 4 - 6 LBS ft maybe even loose torqueand youwill more then most likely suffer power lose as well! wether if its in the low end or topend, all im saying is that a Naturaly aspirated motor involves alot more tuning then some people think, hey im a Subaru driver, but i also own a Mitsubishi starion, late
Old Dec 13, 2003 | 05:12 PM
eclipsegst22681's Avatar
<FONT size=2>Well for $200 you can't get that much but here's a little suggestion get a high performance thermostat. It'll open up more to keep your engine cooler to give you more horses. That you can do with a lil pocket change left. And if you're goin to get an air intake you need to get a K&amp;n typhoon air system that's one of the best. </FONT>
max3
Jul 21, 2007 04:46 AM
Eclipsel3oy99
Sep 9, 2005 12:50 PM
sreps
Jan 21, 2005 08:55 PM
soambah
Jun 30, 2004 09:27 PM
vtf-1
Jun 15, 2003 05:50 PM
