Need Help
Old May 14, 2006 | 01:29 PM
StvPk87's Avatar
Default Need Help
Okay awhile ago a friend and I put a new head unit and subs in my car. Well after we finished installing everything I turn the car on and everything is going great, then (since it was dark out when we finished) I turn the headlights on and I have no gauge lights or lights that light up where the a/c and heater and that stuff is. I checked all the fuses many times and everyone of them is fine. The gauges work find too, but there isnt any light. I also tore out the face plate to check all the bulbs and the bulbs were also fine. So my question is what is wrong and how do I fix this?!
Old May 14, 2006 | 02:30 PM
93eclipsegsx's Avatar
Default RE: Need Help
there is a little **** on the left side of your gauge cover with a little lightbulb, you can turn it so you can dim your lights. try that and see if it works.
Old May 14, 2006 | 02:52 PM
StvPk87's Avatar
No its not because of that ****, I'm not that dumb lol. There is no illumination at all.
Old May 14, 2006 | 02:53 PM
paintballproam's Avatar
what size amp are you running? Are you running the stock alt?
Old May 14, 2006 | 02:54 PM
i know alot about stereo equipment, so i will try to help you out
Old May 14, 2006 | 02:59 PM
StvPk87's Avatar
My amp runs 450 rms, mayb 400 i dont remember to be honest. Its a fosgate amp. But I dont think any of my stereo equipment is making the lights go out. I am pretty sure though that that is what caused the failure of gauge lights. They worked before we installed everything but now they dont. I'm wondering if there is a switch or something like that that might have been ruined. Or if that theft protection stero **** from the factory had anything to do with all of this. I dunno... O and yes im runnin the stock alt. There wasnt a need for a better one.
Old May 14, 2006 | 03:06 PM
Ok, At least you know what you are doing with systems. I know people who try to put a 2000watt ebay amp on they're car with the stock alt and then wonder whats wrong lol
Old May 14, 2006 | 03:17 PM
StvPk87's Avatar
Lol yea I know those types of people. Too bad I cant fix this damn light problem though. Thanks for the replies though.
Old May 14, 2006 | 05:32 PM
sometimes my gauge lights will go out but all i do is replace the tail light fuse and then it works again.
Old May 15, 2006 | 06:54 PM
magnet's Avatar
this SAME exact thing happened to me, was a ground wire I forgot to hook back up under the head unit. Once I put it back to ground all my lights worked again.
