Need Help
Old May 15, 2006 | 08:59 PM
StvPk87's Avatar
Default RE: Need Help
Yea see I thought I forgot to connect a wire somewhere along the line when I first hooked it up, so i checked through it all but it was all hooked up. This weekend I might just go tear everything apart and see if there is anything I could have missed. I might also try to put in a new ground wire. ( I used the ground wire plug thing that the factory used on the factory deck). I dunno....
Old May 15, 2006 | 10:44 PM
Sanguinius's Avatar
Did the head unit have a lighting wire? Did you cut/splice wires or did you get a harness adapter? If cut and splice I'd say you likely cut the dimmer wire rendering the dimmer inoperable.
Old May 15, 2006 | 11:13 PM
StvPk87's Avatar
I bought the adaptor but with it I still had to splice some wires. Oh **** come to think of it I cant remember if I connected the dimmer the correct way (I think I spliced it in with another wire cause I didnt have anymore connectors and wasnt going to go all the way to the store)...hmm i sure hope that is it, I think I'll check tomorrow after work! Damn if that is it I'll feel pretty stupid though lol....
Old May 15, 2006 | 11:25 PM
Sanguinius's Avatar
UGH... LOL I betcha that's it dude. I certainly hope so. I'd rather feel dumb and have everything work than not feel dumb but still be hunting gremlins.
Old May 16, 2006 | 10:10 PM
StvPk87's Avatar
Ok i just tore my console apart. I found that I left the negative dimmer wire running to the head unit unconnected and taped up. I remember that I did this too because there was no dimmer positive wire on the head unit. there was an illumination wire on the head unit but there was also a negative illumination wire on the harness which is where i wired those two together. I remember not exactly knowing what to do or if I needed the dimmer so I just left it. Do you guys think I should connect the negative dimmer switch to the power line? I would just do the usual trial and error but i dont know if I even have connectors laying around and all the tools are in the garage on the other side of the property. Do you think that will do it?
Old May 21, 2006 | 05:33 PM
StvPk87's Avatar
okay i just got done screwing around with the wires. I did come across some good news and bad news....I decided to connect the negative dimmer wire to my power wire and bam I had all my lights on and working, sort of. The good thing is they worked, the bad part was they worked *** backwards...when my headlights are off the lights are all powered, but when I turn the headlights on the lights all go out again. I tried hooking the neg. dimmer wire to some of the other wires but none of them worked. So how do you think I can get them to light the right way? do you think it could be as easy as turning the switch on when I hook them up and after everything is hooked up turn it back to off? I dunno I dont think that would work though...I dunno, advice will be greatly appreciated
91 eclipse gs
1st Generation
Sep 26, 2007 07:03 AM
96eclipsedohc
Feb 8, 2007 09:20 PM
OriginalMirage
Jul 17, 2006 12:53 PM
tuss2oo5
Apr 3, 2006 10:33 PM
Richie03
Dec 12, 2005 11:14 PM
