NEED HELP
Old Mar 11, 2007 | 03:26 PM
bigjake722003's Avatar
Default NEED HELP
Just got an intake for my gsx and there are 3 grommets 1 small two big.......i have the small one connected and the 1 big one connected but dont know where the other one goes.....it was disconnected when i took off my stock......need input
Old Mar 11, 2007 | 05:00 PM
93eclipsegsx's Avatar
Default RE: NEED HELP
what year?
Old Mar 11, 2007 | 10:03 PM
silvercoupe97's Avatar
1 goes to the valve cover (small hose)
1 goes to the bov (large hose)
1 goes to the breather tube from the EGR (medium hose), which is found under the battery in 2Gs (not sure on 1Gs)
Those are common throughout the years. Now, are you saying that the previous owner capped all 3? There may be extra nipples on the intake tube as there are 1 or 2 extras on mine, if you have an aftermarket intake tube.
Old Mar 11, 2007 | 10:08 PM
I have the BOV attatched a small hose which goes almost underneath the original air box then and a medium size hose which goes to the valve cover then there is an extra nipple and i have no idea where it goes
Old Mar 11, 2007 | 10:43 PM
What year car are we talking about? That will help us help you better.
Old Mar 11, 2007 | 10:47 PM
Here's a 2G
and here's a 1G
All of which can be found here
http://members.shaw.ca/dsm.1000q/Eng...r/2G/index.htm, which was also posted in the sticky section in here.
Old Mar 12, 2007 | 10:06 AM
1996
Old Mar 13, 2007 | 12:55 AM
That would be the 3 that I posted then.
The bov should be like it shows above, the valve cover tube should be the same, and the EGR is the one that goes underneath the intake piping and is the only one that isn't shown. Your intake pipe may have extra nipples too. Click the link under the pics and it may help you a bit more too.
Your bov recirc line shouldn't be going to the bottom of the intake...do you have a pic. Your tubing seems all wrong.
91 eclipse gs
1st Generation
Sep 26, 2007 07:03 AM
96eclipsedohc
Feb 8, 2007 09:20 PM
OriginalMirage
Jul 17, 2006 12:53 PM
tuss2oo5
Apr 3, 2006 10:33 PM
Richie03
Dec 12, 2005 11:14 PM
