Need Radio Help
Old Jul 23, 2006 | 10:13 PM
WhiteTrash93's Avatar
Default Need Radio Help
Anybody know where I could run the memory wire for my head unit? The one going to the wire harness has a short or something it isnt live anymore? Anything in the fuse box that is hot when the car is off? Or could I just run it to the + bat. post? And if so should I use a fuse with it??
Old Jul 23, 2006 | 10:29 PM
2nd g eclipse gst's Avatar
Default RE: Need Radio Help
there should be another memory under there somewhere mine blew out too my other memory is a thick red wire try looking for that and if you do run it to the batt. i would definetly use a fuse...
Old Jul 23, 2006 | 10:31 PM
ORIGINAL: 2nd g eclipse gst
What size fuse should I use?
Old Jul 23, 2006 | 10:32 PM
also did you check your fuses to see if the fuse to the radio busted maybe all you needa do is replace da fuse...
Old Jul 23, 2006 | 10:33 PM
i would say a 10 for the fuse...
Old Jul 24, 2006 | 02:37 AM
eclipsegs187's Avatar
Memory wire? I yanked out a couple head units and I never came across a memory wire. Are you guys talking about the power wire?
rosetex
Dec 8, 2008 06:14 PM
adambl03
Apr 18, 2007 12:52 PM
ric
Aug 25, 2006 03:37 PM
vhinojosa0001
Jul 6, 2006 12:42 PM
wbrod
Nov 3, 2005 09:15 AM
