need some help fast with an oxgen sensor problem
the post cat sensor is still good but when i looked at the wiring i didn't see anything that looked like it had been cut is that were the the pre cat sensor should wire up?
i wish i still had my eclipse... i'd jack it up and look for you bro but i just can't remember where it goes.... can anybody that owns a 420a do this for a member in need?
thanks for the help i've been all over the net and can't find anything and i don't wanna go under there and just start pulling things apart that don't need to come off i'll try to get some pics up so you guys can see my $200 purchase.
I just replaced mine. The wire runs through a plastic coated metal wire coil on the bottom left front of the A/C compressor and up across the front of it to a plug that is above the A/C and to the right of the power steering pump. There is a metal bracket kind of Y shaped and the plug has a plastic push clip that holds it there.
1998blackgst 240
04-12-2005 12:56 PM
