need some help fast with an oxgen sensor problem
Old Aug 28, 2007 | 11:53 AM
Default RE: need some help fast with an oxgen sensor problem
There are 2 sensors on the exhaust. Cant you follow the other one? Or have they both been cut?
Old Aug 28, 2007 | 12:09 PM
kenlrw39's Avatar
the post cat sensor is still good but when i looked at the wiring i didn't see anything that looked like it had been cut is that were the the pre cat sensor should wire up?
Old Aug 28, 2007 | 12:50 PM
RCJr9186's Avatar
i wish i still had my eclipse... i'd jack it up and look for you bro but i just can't remember where it goes.... can anybody that owns a 420a do this for a member in need?
Old Aug 28, 2007 | 01:38 PM
kenlrw39's Avatar
thanks for the help i've been all over the net and can't find anything and i don't wanna go under there and just start pulling things apart that don't need to come off i'll try to get some pics up so you guys can see my $200 purchase.
Old Aug 30, 2007 | 03:44 PM
chopper1's Avatar
I just replaced mine. The wire runs through a plastic coated metal wire coil on the bottom left front of the A/C compressor and up across the front of it to a plug that is above the A/C and to the right of the power steering pump. There is a metal bracket kind of Y shaped and the plug has a plastic push clip that holds it there.
Old Aug 31, 2007 | 10:09 AM
kenlrw39's Avatar
thanks i'm gonna go check it right now
ProjectDrknss
Aug 9, 2007 01:39 AM
aorozco2
Jul 24, 2007 04:43 PM
Dreamer13
Jan 17, 2007 10:51 PM
sickend
Sep 12, 2006 06:25 AM
1998blackgst 240
Apr 12, 2005 12:56 PM
